Pelton Turbine Needle Valve
We have a small Pelton Wheel type hydroelectric project with two needle valves. The needle valves have an internal hydraulic actuator and one of them has a compromised seal and is leaking oil. That is a big problem in the environmentally sensitive area. I've seen needle valves with a hydraulic spear actuators that were external so that a leaking seal would not get into the water. We are thinking this would be a good option for fixing the problem. I have not found many manufacturers of needle valves, are there any in the US? Any additional recommendation to fix this issue? Thanks!
RE: Pelton Turbine Needle Valve
The turbine is a Sanden from Norway from 1985. It's rated 850kW with 550Ft of head and 360RPM. I don't have the actual head available but it's at least several hundred feet.
I tried to attach two photos, one of the inside and one of the outside, but it may reduce to just one. I'll post the other one if need be.
Have you contacted the manufacturer to see if they have options available?
If you must use hydraulics, consider finding biodegradable fluids, or propylene glycol/water mixtures, to reduce environmental impacts.
What you have is an axial control valve or sometimes axial plug control valve.
Mokveld in Netherlands make very good ones, also petrolvalves, Dyna-flow and others, but use these search terms and you'll be better informed.
Most of these operate via a gear mechanism to an external actuator, but then have some interference with flow.
