Splines and arrow size bug or option not set correctly?
In Autocad 2000 I am having a problem when using spline leaders and large arrowheads – go figure! If I modify the current style to support an arrowhead size of 6 feet and I check the DIMASZ and it is set to 6 feet; when I draw the leader (no text or mtext) the arrowhead is either much smaller than 6 feet or no arrowhead is drawn. If I check the proprieties of the spline the size is 6 feet but the spline type is now set to (spline no arrow!) It changes to splin with arror only when I reduce the arrowhead size to some magic size like 3 inches – help? Am I missing another variable set somewhere that is preventing the parameters set by the dim style dialogbox? Thanks
RE: Splines and arrow size bug or option not set correctly?
