difference between FEED and FEL
What is the difference between front end engineering design and Front End loading. Literature available on internet mentions FEL as 1, 2, 3 and so on. If someone has worked on both FEED as well as FEL, please guide.
RE: difference between FEED and FEL
FEL-1 covers not only the engineering part but other project areas such as the business case, economics, shareholder management, environmental issues etc.
You can read more at: http://wiki.iploca.com/display/rtswiki/2.1+Front-E...
Dejan IVANOVIC
Process Engineer, MSChE
