HVAC Industry vs Piping Industry
I have several questions to ask. I have piping background wanting to most between HVAC vs piping.
What the Pro vs Cons HVAC vs Piping:
Which one pays the most?
Which one has the least up and down and for stable?
Which one is easier start a business?
Which offers easier employment.
RE: HVAC Industry vs Piping Industry
For an engineer or designer, probably not much difference; do some calcs, put some lines on a plan.
For a tradesman, as I suspect you are, new piping goes in before the building is covered. HVAC goes in after. Do you like to work outside, or inside?
No idea; I'd guess it depends on how badly your skill is needed on a particular site.
These days, nobody knows. Here in SoFla, there's a steady business in AC replacements in older homes.
Here in SoFla, judging by the people we've hired, the barriers to entry are not substantial. Our experience has taught us to work with older companies. Getting to be an older company is clearly not easy.
I haven't seen a plumber or an AC tech put in an easy day, except for the ones who have just branched out on their own, who will talk the ear off a brass monkey, telling you how hard they work. ... while some minion does the actual work.
Mike Halloran
Pembroke Pines, FL, USA
The part where you size ducts for buildings is not a whole lot different from sizing pipes for buildings. Since buildings are mostly custom, I'd expect relative stability, and you get to work for people who are probably engineers.
The part where you design equipment to connect to the ducts, like air handlers and condenser units, is a highly competitive consumer product business. Expect low margins, management with zero technical skills, crazy schedules, high turnover, and serious offshore competition.
You can probably get some better answers if you are more specific about what sort of things you have done, and what you think you're capable of doing.
Mike Halloran
