ANSYS TimeHistory Postprocessor in other coordinate system
Hi to everyone,
I would like to list all the x-strain results for a node for all timesteps. I think the best solution is to use time history postprocessor. The problem is that i need to read the results in the coordinate system of the solution (RSYS,SOLU), but time history postprocessor only lists the results in the global coordinate system. Any ideas that could help please?
Thank you in advance!
RE: ANSYS TimeHistory Postprocessor in other coordinate system
good luck
