Slanted Dimension Text
Any way to dimension an element and have the text slanted 15 degrees like the rest of the normal text? I am currently using the italics font (which is undesirable) or placing text manually (which is cumbersome).
RE: Slanted Dimension Text
The process is so tedious and the rewards are so meaningless that I have not seen anyone going through this route though. But if you have reasons, there is a way.
I was hoping that I had overlooked something and slanting dimension would be as easy as changing a setting somewhere (as it should be) but I am seeing now that this is probably not the case.
Earl
