Tech referance on MV clearance in substations?
I am looking for a source to referance on the standards for safe clearance of MV equipment energized parts (2300v)in a substation.  How low can this voltage bus be installed and still be safe for people entering the sub.
I have a transformer with 2300vac primary and side mounted bushings. THe bus is insulated now but I want to referance a standard for clearance or a standard for limiting access.
Please advise.
RE: Tech referance on MV clearance in substations?
In ANSI regions where the [1999] National Electrical Code prevails, Articles 110 part C and 490 specify various dimensions and guarding.
