I am looking to create cable runs in Creo Parametric
I am looking to create cable runs through a chassis that will have to cover multiple variants.
So the lengths and positions of the cables will change.
Is there a way to fix the start and end of a cable that will then allow for flexibility to change the length of cable to fit around the chassis?
I am using Creo Parametric and do not have the 'Cable' add on module.
I can create the cable run using a sweep along a curve through points.
This does make things long winded for changing point positions to move the curve.
Any ideas?
Cheers
Any ideas?
Cheers
RE: I am looking to create cable runs in Creo Parametric
