1 M height painting requirement
Good afternoon Gents,
I always arguing with the painting subcontractor about this issue.
I suggested to them not to make square edge (Sketch-A) at the 1 M point. Making little bit slope (Sketch-B)
If the edge is square the painting there is tendency to peel off.
Please refer to sketch A and B in the attachment.
Any other advise is highly appreciated.
RE: 1 M height painting requirement
hello friend
what is a tickness of film?
wich one the painting system?
Hi Figueredo,
It is Coaltar Epoxy 400 micron DFT.
IRstuff,
We are not arguing about scope work. It is clear the subcontractor scope to paint with 400 dft Coaltar Epoxy only 1 M height.
The question is the edge at 1 M must be square like sketch A or slope like sketch B.
The painting subcontractor put masking tape exactly at 1 M. After painting completed they remove the tape. Looks nice and tidy like sketch A.
But in my opinion there is tendency peel of on the top edge because the top edge is square. That is why I asked them to make it slope like sketch B.
If the surface preparation is SSPC- SP 5 is not needed anything, just that when you withdraw the tape you should do when the paint cure touch to prevent loosening of the applied paint .
My other question is : is it just this area which will be painted with this product? Are other nearby areas will be painted with other specification ?.
If only that area to take that picture and the tank will be filled at higher altitudes dont worry about it only when you withdraw the tape be careful .
regards,
My point is that if you want a bevel per paint profile B, THAT should be in the contract. Your contractor is completely within his rights to object to the addition work you are imposing AFTER you've signed the contract. I'm fairly certain that what you are asking for will result in a noticeable increase in scope.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Good morning Gents,
Thanks for the advice.
Figueredo,
The surface preparation is SSPS SP10.
Only bottom plate and 1 M shell plate will be coated by coaltar epoxy. The rest is bare metal.
Yes during operation the product in the tank would be above 1 M except during maintenance which will be after 5 or 10 years.
IRstuff,
The project specs and the subcontractor procedure do not cover that detail.
I understand this shall be cleared during kick of meeting or when the procedure was being reviewed. But somehow the procedure had been approved by the higher level who looks like has very less experience in painting.
After further hard discussion the subcontractor agree with my suggestion because they do not need to apply a masking tape and remove again after painting work is completed.
Since this is internal painting there is no issue about appearance.
If you are painting only the bottom 1m and leaving the remainder of the tank uncoated, it matters little whether the termination is beveled or square....that interface will be a flaking problem either way.
I also agree with IRstuff that you are increasing the scope of work of the painting contractor, thus expect a change order for cost increase.
Good morning Ron,
Practically it is not really slope like sketch B.
So there is no additional effort or cost. But there is no more man-hour for putting and removing the slop.
