NX journal - run journal inside other process
Hello everybody,
I have one question:
It's possible to run journal when I use other process, and then return to this process?
e.g. I use command Rapid Dimension. I want break this command, run my program and return to rapid dimension window (all with journal).
Maybe somebody can answer me.
Best regards
Michał Nowak
NX9 & Tc10
RE: NX journal - run journal inside other process
If I'm interpreting your requirements correctly, I don't think it is possible with a journal.
My interpretation: run journal, journal opens rapid dimension dialog, journal performs one or more actions, journal exits leaving the dimension dialog open.
Journals do not give you direct access to the GUI dialogs; they cannot open or display the normal interactive dialogs.
www.nxjournaling.com
