technical accuracy of FEED pckage
In the creation of a chemical process plant, an owner has engaged an engineering contractor to carry out Front End Engg. Design.
How will you judge whether the FEED package is good enough for Detailed Engineering? What I mean is how will you judge that the FEED package is neither under developed or over developed. In my opinion, an under developed package will bring out various change orders. An over developed FEED might restrict the leeway of EPC contractor. Thanks.
RE: technical accuracy of FEED pckage
http://www.eng-tips.com/viewthread.cfm?qid=383646
