HOW TO: External Python Modules from Abaqus Python Interpreter
So recently, I've spent a good deal of time trying to get external python modules (that do not come with the Abaqus installation) in order to cut down on some of my file I/O time extracting Abaqus results for use in other programs (currently MATLAB since that's what most of my current tools are written in or interfaced with). You probably know that Abaqus's version of Python comes with NumPY, though the version may be a little outdated (I think the NumPy version with Abaqus 6.13 was too low for the last major rewrite of SciPy). My motivation was to be able to save in MATLAB readable .mat files rather than humongous ASCII text files (or reverse engineering NumPy's compressed format). For that, I needed the hdf5storage module (which relies on h5py) in order to write MATLAB version 7.3 .mat files (SciPy can do earlier versions) due to the size of my data files. I dabbled with trying to get Abaqus's ODB API modules imported on my system Python install, but I didn't get too far with that. I'm guessing they've compiled their own Python interpreter with their modules linked as shared objects rather than the usual Python package setup. So here's what I was able to do as far as getting more functionality within Abaqus's Python version...
Environment Details:
Abaqus Version: 6.14-1 (though I believe the approach should work for earlier versions as well, you'll just need to make sure you're using the correct version of python for your external installations). This version of Abaqus comes with Python 2.7.x as it's interpreter.
OS: Red Hat Linux 6.x, which comes with Python 2.6.x I believe. I separately installed Python 2.7.x as an alternate install (called using python2.7 rather than python in order to not break any OS python scripts). You'll want to make sure you have a similar Python major version installation as your Abaqus Python version.
Process:
The way python module installation works on Linux (if you're using pip) is basically, you run "pip install package-name" to get additional modules. Essentially, what pip does is download the tarball for the package you want, extracts it, then runs "python setup.py install" from the folder it extracts. This builds and deploys that package to your python's site-packages/ folder. On my system, I believe this was located in the /usr/local/lib/python2.7/site-packages folder.
In order to install a module in Abaqus, the process I used was to install the module for my system python folder for the same version of python that Abaqus uses, then copy the folder from the system python site-packages folder to the Abaqus site packages folder, which is located at $ABAQUS/6.14-1/tools/SMApy/python2.7/lib/python2.7/site-packages (replace the 6.14-1 with your system's version and the $ABAQUS variable is the location of your Abaqus installation). For some packages this was pretty straightforward. For others, which rely on external libraries or additional dependencies, YMMV. For dependencies that are python packages, I basically installed the package I wanted, then opened up an abaqus python session, tried to load it and added packages based on the missing module errors that were generated. I was able to get most of the packages I wanted working using this approach. Note, it appeared that sometimes, installing a module put the needed folder nested one deeper in the site-packages folder than Abaqus liked. The folder containing the package in the Abaqus folder should have the __init__.py and _version.py files in it's root.
Packages I Tried:
NumPy: Yes, Abaqus comes with NumPy, but it is a much older version of NumPy. I think 6.14 comes with Numpy 1.4.x, which might be new enough to support SciPy, but I'm pretty sure the 6.13 version is older and has limited/no support for SciPy. If you want/need to upgrade your NumPy, do not use the latest version (1.9 as of writing this), but instead use the newest 1.8.x release. NumPy 1.9 removes support for it's oldnumerics submodule, which I found was needed for Abaqus/CAE. I believe the install for NumPy was straightforward and didn't have any issues with dependencies.
SciPy: This was again straightforward, but I haven't really used it other than loading the module without errors, so I can't 100% say it's working correctly, but I don't think there's any weird external dependencies, so I'd expect it to work.
matplotlib: So, I could barely get this to install on my system python due to libpng issues. I managed to get it importing fine in Abaqus, but it gives libtk/libtcl problems when I actually try to make a plot, so this isn't working yet. I didn't really have a huge need for it, so I didn't spend too much time trying to get it to work
Numba: This is a neat package that does just in time compilation to speed up your code. It has an external dependency of LLVM 3.5 and I had a hell of a time getting it to work due to the llvmlite package it uses to interface with LLVM. I ended up having to download a prebuilt version of llvmlite from https://binstar.org/numba/llvmlite/files (which was not easy to find in the first place). I was able to get it to work, but I didn't see any speedup since it doesn't support list comprehensions (which the main bottleneck of my code). If you have a lot of numpy operations in an inner loop, it should help speed things up though.
line_profiler: This was a nifty package that gives line by line data on where your function is spending time. Once you get the module installed, you can invoke it with 'abaqus python -m kernprof -l -v scriptname.py args' (the -m is python for running the module, -l -v are kernprof arguments with -v giving verbose output, you can also view results with 'abaqus python line_profiler profresult_file). This worked pretty well once I figured out how to invoke it. You do need to add @profile to just before the function you're trying to profile to get results (make sure to remove it once you are no longer running the profiler).
h5py and hdf5storage: Installed pretty smoothly and was able to successfully write to MATLAB v7.3 .mat files. They end up a bit bigger than if you were saving the same data within MATLAB, but it definitely cut down on my I/O time (and removed a step of reading the ASCII file into MATLAB and resaving as .mat for storage and future I/O speed).
Conclusion:
Hope this helps! I imagine you can use a similar process to get things working on Windows, but I make no guarantees or promises with that.
RE: HOW TO: External Python Modules from Abaqus Python Interpreter
I'm having the same problem. I have abaqus 6.14 which runs on python 2.7, and im currently working with some data that is generated by an external module that needs the latest release of scipy, numpy, and , especifically, python 3.3+ . When i try to import the modules, there are invalid syntax errors deep in the external module code, in one of the class constructors.
Is there anyway to run this module on abaqus PDE, instead of having to generate all the data to an ASCII file within spyder IDE on python 3.4, and create another abaqus script that reads and uses the data to create the models?
The Abaqus python won't be compatible with the python3 modules, so importing those modules like I did will not work.
The python2.x version of those modules doesn't support the functions needed? Could you rewrite your external module to utilize the 2.x versions of scipy/numpy?
I think not, because the problem isn't the numpy and scipy extensions, the problem is that it requires python 3.3 at least.
My solution was to write the data to file using the spyder dev environment, and now read the datafile into an abaqus script.
Thanks for clearing this out !
Quote (AmilcarPT)
What is it that is requiring python 3.3? If there is a 2.7 compatible version available, you can use the method above to integrate it into your Abaqus install. If not, you're stuck doing it the way you are currently writing the data in a different version of python, then reading it into your Abaqus script.
The toolkit that i've download is sci-kit nano and it's latest release contains specific functions that I need in order to generate point coordinates of a nano structure, and this external module requires python 3.3.
When i try to import it in abaqus environment, it gives me an invalid syntax error when importing some sub module that has a class definition with an inheritance of a metaclass, which i don't know if it is a supported feature in python 2.7. (and i apologize for the lack of technical details, im a student and just started to use python and abaqus ...)
It looks like sci-kit nano only supports python 3.4+, so you won't be able to integrate it tightly with the python. Depending on the amount of file I/O and number of simulations you're running, it might be worth getting the h5py module working. I'd recommend keep your process the same if it's fast enough to get the results you need.
I just wonder if somebody try to install and use pypbs on Abaqus 6.14? Will above described approach works in such case?
Thanks.
Huge thanks for this, its a really helpful post. I've wondered whether there was a way to do this and now I know!
@mikechy: As long as the package you want to use is compatible with Python 2.7, it's got a chance to work.
@adfergusson: Glad it helps! It's too bad SIMULIA doesn't package pip with their python installation to make this even easier!
Hi Man,
I have spent so much time trying to figure out what you did smoothly?
I am trying to import h5py in Abaqus 6.14 student edition, and I have faced almost every kind of error while trying to fix the errors. I am running a windows 10, with an anaconda python 2.7.10, and abaqus python version is 2.7.3.
Can you detail about the h5py installation again? I would really appreciate it man.
@anshmania: Follow the process in the original post. Basically, install it into your Anaconda distribution and then copy over the relevant folders from the Anaconda site-packages folder to the Abaqus site-packages folder. Make sure you're grabbing both the packages you want as well as any dependencies (it can take a few tries before you have everything in place).
The major dependencies for h5py were, NumPy, Cython, and Six, as far as I know and the good thing about Anaconda is it comes preinstalled with all that stuff. So I picked out those libraries and copied them to the specified folder but no luck yet.
Do you have h5py running on your Abaqus? Have you tried using h5py particularly to create a .hdf5 or access one? If that is the case I will keep trying.
Thanks for the prompt reply man.
This is my most recent error log, does it make sense to you?
>>> import h5py
File "C:\SIMULIA\Abaqus\6.14-2SE\tools\SMApy\python2.7\lib\site-packages\h5py\__init__.py", line 27, in <module>
from . import _conv
File "h5py\h5t.pxd", line 14, in init h5py._conv (C:\aroot\work\h5py\_conv.c:6966)
File "h5py\numpy.pxd", line 66, in init h5py.h5t (C:\aroot\work\h5py\h5t.c:19628)
ValueError: numpy.dtype has the wrong size, try recompiling
>>> import h5py
File "C:\SIMULIA\Abaqus\6.14-2SE\tools\SMApy\python2.7\lib\site-packages\h5py\__init__.py", line 17, in <module>
from . import _errors
ImportError: cannot import name _errors
Thank you for your support man.
Yep, I had it working with my Python. I recall that one being relatively easy to get going. had a few system libraries to install, but otherwise didn't have any trouble getting it going. Copy things over, try to import, resolve error of missing packages (python error messages tend to be pretty useful), repeat until working. Make sure you're not trying to overwrite with too recent of NumPy or you'll break other stuff.
From googling: "This means that the version of h5py you have was built against a more recent version of NumPy. You could try upgrading your NumPy install to 1.7."
Install a version of h5py that is compatible with the Abaqus version of NumPy.
