Determining damping coefficient of a shock
Have a couple shocks that I want to test for their damping coefficients. Does anyone know any good testing methods that can be done without using highly sophisticated measuring devices to determine the damping coefficient?
RE: Determining damping coefficient of a shock
You can't measure crankshafts and connecting rods for oil clearance using a tape measure. Same concept. If you want to make the right measurement with the right degree of accuracy, you need the right measuring tool ... and in this case, that's a shock dyno.
Backyard methods like installing it on a car and jumping up and down on the bumper will tell you whether it has some damping, or none.
