Metric Tolerances
Metric Tolerances
I am trying to find a chart which relates the number of decimal places of a metric dimension to the, "Unless Otherwise Specified" tolerance.
In deference to the english system in which the number of decimal places does not specify the tolerance, the metric system does indicate the tolerance to be applied for the number of places.
Any leads would be greatly appreciated.
RE: Metric Tolerances
Viktor
http://viktorastakhov.tripod.com
The application I have is not a "fit" application but rather tolerances which reflect the capability of a manufacturing process.
Finally, DIN7168 is obsolete and replaced by ISO2768 which is available on the ISO website. I would guess the others I mentioned are also replaced by ISO standards.
Hope this helps,
Jim
GDT GUY
ISO TOLERANCES, IF NOT INDICATED: MACHINE WORKED SURFACES
DIAMETRICAL DIMENSIONS JS13 -js13, LONGITUDINAL DIMENSIONS
JS14 - js14, OTHER SURFACES JS16 - js16.
Sometimes it's just noted:
overall tolerances:+/- 0,1mm
I'm workin' in a former American factory in Europe and I thought that workin' with those zero's after the comma was an English or American habit? I was never taught that in school over here!
Greetings
pvdvyve-Antwerp-Belgium-Europe
Greetings from Belgium (Europe).
