SHOP DRAWINGS
SHOP DRAWINGS
SHOP DRAWINGS
Does anyone know what (W.T.S.) would stand for on a shop drawing of a diagonal brace with bolted angle connections?
RE: SHOP DRAWINGS
Probably the quickest solution would be to call the fabricator and ask.
RE: SHOP DRAWINGS
Ask and ye shall conceve perceive.
Mike McCann, PE, SE (WA)
RE: SHOP DRAWINGS
Welded Tubular Steel. Water Tight Scuttle. Weights. If it's the weights of watertight scuttles made of welded tubular steel, then it'd be a wtswtswts.
RE: SHOP DRAWINGS
I don't recall W.T.S, however, I've used W.T.F.on many shop drawings.
RE: SHOP DRAWINGS
MIL-STD-1111 is helpful.
RE: SHOP DRAWINGS
I did ask the fabricator. And all you comedians lose...LOL
It means Wired To Ship...
Thanks all! :)
RE: SHOP DRAWINGS
So if it you mean to say the weights of watertight scuttles made from welded tubular steel that are wired to ship, then you mean "wtswtswtswts".
RE: SHOP DRAWINGS
I want was he's drinking ↑ cheers
