Re-chase anchor bolt threads
I was asked to inspect existing anchor rods that are 1.5" diameter, cast in place, located outdoors. They anchored a piece of equipment that had been temporarily removed, but would be re-installed after my inspection.
Overall, they appeared to be in good condition. Almost all of them showed signs of very minor surface corrosion and thread wear but nothing unexpected.
I briefly spoke to the contractor who indicated that he planned to "re-chase the threads". After a quick google search, it seems that this is simply a method of cleaning the threads since no material is actually removed.
Is this correct? Any potential issues with re-chasing threads?
RE: Re-chase anchor bolt threads
Call him and ask directly...
Mike McCann, PE, SE (WA)
I do plan to talk to him about this process, just wanted to do my homework so that I could have an intelligent conversation. He probably would not mention any adverse effects this process could have on the anchor rods....if there are any.
"Chasing" threads involves running a threading die over an already formed thread to remove any adherent contaminants and to cut off any native material projecting after a dent, nick, or other plastic deformation.
It is not precise to say that it removes no material, unless the thread is already/still perfect.
"Re-chasing" suggests the threads have been chased already, which may or may not be true. It seems pretentious to me.
The rust will probably remove material from the die, which does the die no good. I'd suggest pre-soaking the rust with "PB Blaster" or something similar, to make the die's life a little easier.
Mike Halloran
Pembroke Pines, FL, USA
The OTC tool is well adapted for repairing end damage to isolated studs, i.e., engaging it radially and backwards in a lathe and 'running it off'. It's less well adapted for grouped studs because of the handle.
The NAPA tool comprises what are basically hardened nuts, that may or may not be notched to have a cutting edge. I have chased distorted studs by grinding a notch in one face of the mating nut, chasing the thread, and then using the same nut, reversed, to complete the joint; I'm rarely that lucky.
Mike Halloran
Probably not necessary. Suggest wire brush cleaning, lubrication and move on.
I'd be wondering about anyone who would want to chase anchor bolts.
