Readings between different units
What would be acceptable difference in readings done by different machines and operators.
RE: Readings between different units
I contacted Taylor Hobson because that's who we bought the unit I'm using from and they said 2% if same operator using both units and everything else is exactly the same and 5% if operators are using the same units, spec and trace.
So I wondering how much it would be for different units, I know our other labs they don't even make it anymore.
Running a search for Gage R&R might be useful.
For example, here is a handy introduction to the subject (complete with a link to a spreadsheet)
http://www.dmaictools.com/dmaic-measure/grr
Thanks for the feed back.
You haven't specified what unit or test, Cosmoe615.
My lab is using a Taylor Hoboson S-116 not sure what the supplier of our parts is using.
So it's a roughness testing unit?
Yes, the S-116 a smaller type unit for measuring surface finishes about the size LxW of a kindle
