need a 3d drawing showing different elevation for the suction and discharge side of a fire pump
Basically,
A fellow designer states he cannot abide by the 10D rule (from NFPA 20 10x pipe diameter)since the suction and discharge piping outlets are at different elevations. This is a fire pump replacement project and the outlets for supply from water source and for discharge into facility are permanent. Thanks. I have shown him diagrams from NFPA 20, but he still concedes it cant be done. If anyone has a 3D drawing showing the 10D rule where suction and discharge are at different elevations, it would be appreciated.
Sincerely,
Tim
Sincerely,
Tim
RE: need a 3d drawing showing different elevation for the suction and discharge side of a fire pump
http://www.abspk.org.br/CBSpk/Apresentacoes/Dia04-...
https://dps.mn.gov/divisions/sfm/programs-services...
http://www.piping-engineering.com/layout-arrangeme...
http://www.pdhonline.org/courses/m134/m134content....
Dejan IVANOVIC
Process Engineer, MSChE
Dejan IVANOVIC
Sometimes a little less than 10d is also sufficient.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
