Is it reasonable, to do linear natural frequency analysis for a plastic part of uniform thickness?
A plastic component with uniform thickness which purpose is to protection of surroundings.
Is it okay to consider the plastic as linear material and do modal analysis for the shape?
RE: Is it reasonable, to do linear natural frequency analysis for a plastic part of uniform thickness?
The only thing you could do, is doing a nonlinear step before, to change the stiffness of the material.
