External BOMs
External BOMs
Our company uses BOMs that are a separate document. We insert the SolidWorks BOM outside the titleblock, and copy and paste the information from the BOM, to an external Microsoft Excel file.
Someone has just asked me if it is possible to have an external BOM written-to automatically when we save an assembly drawing. Is anybody out there doing this?
There was a thread about this a couple of months ago, but no one came up with anything. I thought it might be worth another try.
I have experimented with the BOM save-as feature, but this excludes our BOM document headers, and our numbering system has leading zeros. The leading zeros also mess up Microsoft Access, so this is probably not an option.
Hint:
Don't create numbering systems with leading zeros :(
JHG
Hint:
JHG
RE: External BOMs
Theoretically one might be able to write an add-in that detects the save event in an assembly drawing and exports a copy of a BOM to an Excel file. I don't know about cross-linking in order to update an existing Excel file though, never tried to do that. It seems to me that overwriting any existing external BOM each time might be easier to program. It would require some thought to code but it should be doable to one extent or another.
Chris Gervais
Mechanical Designer
American Superconductor
RE: External BOMs
Interesting!
Overwriting the external BOM is not a problem. It is an automatic database output, so I would not want anyone maintaining it manually. If someone wants to see a change history, they would look at the assembly drawing.
Let's take the case that my assembly drawing has a parameter PARTS_LIST in the custom profile, containing the document number of the BOM. I know the name of the assembly. I know the revision of the assembly, and I _need_ to make this match the BOM. At the point someone clicks the save button, the existance of the PARTS_LIST parameter tells us it is an assembly drawing.
One of my rainy day projects is to write a VB program that runs inside the assembly drawing, reads the BOM, and writes it out as XHTML. This comes some time after I learn to program in VB of course.
This has to run from the assembly drawing, since I need the item numbers, and I need to exclude non-parts like weld beads.
XHTML is by far and away to most understandable XML document type, and I can use a style sheet to flag significant information.
All of this is worthwhile if I have an application downstream that can use all of this information. Right now, I don't. I ought to be able to write out the BOM in Excel format, but I won't know how to do this in the forseeable future.
JHG
RE: External BOMs
