Maraging 300 turned brown.
Howdy,
I'm working with some parts made from Maraging 300... parts came out of the CNC with some burrs. They went in a wet tumbler, and after about an hour with water and ceramic tumble media... they turned a light tinge of brown. Almost anodize looking in appearance.
Instant reaction is that it is rust. simplest answer right. But we tumble 17-4, 303, 400 stainless parts all the time. based on the nickel content I would expect it to behave like a stainless.
Is there something well known about mar300 that we are unaware of?
It has a lot of Cobalt in it...and I have no idea what that does as far as corrosion. Did it react with the water? a contaminate in the media such as aluminum, iron oxide from other parts so on? React with the rust inhibitor (we use PDN-50 Detergent... okay now that I looked that up that's my primary suspect).
Thanks!
Thanks!
RE: Maraging 300 turned brown.
M300 is a steel, it will rust.
Thanks!
