Can't open a file from TeamCenter...please help.
We recently upgraded to TC 10 and NX 9. Prior to the upgrade I could double click a file (model or drawing) in TC and open it in NX. Now, with the upgrade, when I try to open a file from with in TC I get an error message. See attachment.
Please help. Thank you!
Thank you,
Trent
NX 8.5.2.3
RE: Can't open a file from TeamCenter...please help.
Could solve you're problem.
Best regards,
Michaël.
NX8.5.3 + TC Unified 8.3
Win 7 64 bit
The problem appears to be "prior to NX launch" related to the FCC not running or able to start.
In a command shell test to see that FMS_HOME is defined and resolves correctly. If it does then check to see if the FCC can be started explicitly with "%FMS_HOME\start_tccs". If not, the error messages should help point to the next suspect.
This could also be Java related and just require setting system env var to resolve the jre location.
HTH,
Joe
