piping design basis
piping design basis
In an EPC project, is the piping design basis the first deliverable. If yes, what activities go into making it?
RE: piping design basis
First things I would want to see are 1) some kind of PFD, 2) machinery/equipment footprints, 3) a plot plan.
A quick search returns this link: http://www.pipingengineer.org/piping-checklists/pi...
Piping Design Central
In piping alone, studies on aspects like geotechnical factors, pipeline access, and land acquisitions are made to establish design basis.
Other studies that may contribute to piping may be scope by other disciplines, such as corrosion control study, material handling, material selection, etc.
From those boundary conditions, the EPC needs to find the seismic zones, archaeology, road/river crossings, and surface disturbance issues.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Pipeline?
Process Plant?
Power Plant?
Pharmaceutical?
On Shore?
Off Shore?
Grass Roots (Green Field)?
Revamp?
Stick Build?
Module Build?
Until we know the answers to these questions it is not possible to give mush help to the OP.
The OP did however specifically ask about the "Piping Design Basis". The Client is normally required to provide the "Piping Design Basis" as a part of 'His' Basis of Design Development (BEDD) Document. This will include the "Code" (ASME B31.1, 3, 4, 8 etc) to be used. The Client is also required to state the "Plant Life" (20, 25, 30 years, etc.) to be used for calculating pipe corrosion allowance and wall thicknesses
Sometimes its possible to do all the right things and still get bad results
I had a process plant in mind when I posted the question. This is response to Pennpiper.
It's basically all the information your client can tell you about the design which pretty much can be taken for granted thereafter, except in unusual circumstances where something might be absolutely necessary to change due to some previously unforseen reason (read that as a potential change order).
1.0 Introduction
1.1 Purpose
1.2 Scope
2.0 Summary
3.0 Project Overview
4.0 Abbreviations and Definitions
4.1 Abbreviations
4.2 Definitions
5.0 Reference Documents
5.1 General
5.2 Reference Software
5.3 Project Specifications
5.4 Client Standard Documents
5.5 Industry Codes and Standards
5.6 Recommended Practices and Specifications for Engineering
5.7 Drawings and Lists
6.0 Design Execution
6.1 Units
6.2 3D Modeling
6.3 Plot Plan and Layouts
6.4 Escape Routes
7.0 Design Conditions
7.1 Design Life
7.2 Design Pressure and Temperature
7.3 Environmental Conditions
7.4 Pipe Sizing
8.0 Piping Materials
8.1 Material Selection
8.2 Piping Class
8.3 Selection of Valves
9.0 Piping Layout
9.1 General
9.2 Pipe Rack Piping
9.3 Scraper Trap Piping
9.4 Vents and Drains
9.5 Utility Hose Stations
9.6 Piping Isolation Requirements
9.7 Dead Legs
9.8 Sample Connections
10.0 Fire Water Piping
10.1 General
10.2 Branch Piping
10.3 Block Valves
11.0 Access and Clearances
11.1 General
11.2 Overhead Clearance
11.3 Operational and Maintenance Requirements
11.4 Distance between Pipes
11.5 Valve Access
12.0 Material Handling
13.0 Valve Installation
14.0 Instruments
14.1 General
14.2 Flow Instruments
14.3 Temperature Instruments
14.4 Level Instruments
14.5 Corrosion Monitoring Access Fittings
15.0 Special Piping Components
16.0 Piping Flexibility
17.0 Pipe Supports
18.0 Insulation
19.0 Cleaning and Passivation
20.0 Piping Tie-Ins
