CODE 1073741819
CODE 1073741819
HI all
I know this get asked all the time why and how but
how do i go about fixing this
what is the first thing i look into
does it have a specific origin like coding or assembly
just how do i start in the process of fixing this..
HELPPPPPP
HELPPPPPP
RE: CODE 1073741819
Try to see if the path of your folder where your file is save present one of this characters. You can do a test: Copy you file to a new folder in desktop, do not use any character that abaqus can't reconigze to name the folder. Then run your analysis and see if it works.
I hope you can solve your problem with this tip.
RE: CODE 1073741819
.msg and .dat has no errors reported and no .sta file to be found..anyone else have an idea?
