ACI 318-63 What is the allowable compressive strength of plain concrete for WSD
I am designing a CSM wall. we are using Plain Concrete provisions as there is no codes for Cutter Soil Mix walls.
I am using working stress design, to get a safety factor for applied stress over allowable stress.
I need to find the allowable compressive strength of plain concrete
I see factors of 0.6 and 0.45 and even 0.33 times f'c, but no solid reference
Mostly papers I can find on the net. I don't have a copy of 63 code.
I am sure they have it there.
If anyone can help , I will be grateful
A. D. Ketin
RE: ACI 318-63 What is the allowable compressive strength of plain concrete for WSD
What's a cutter soil mix? Is that a soil-cement mix?
Buggar, Yes it is soil-cement mix. Based on test results 900 to 1000 psi is used for f'c.
I needed the allowable for working stress design so I can calculate the safety factor,but as dcarr82775 suggests
factors 0.4 or 0.45 is used for f'c to get that WSD allowable. I don't have 89 code but try to find it to see.
thanks again
Alan
A. D. Ketin
I couldn't access that link at work..Somehow it is restricted...Can you write the web address so I can go directly there,
or use VPN client to get around it.
Alan
A. D. Ketin
