NX TITLE BLOCK - MATERIAL
thread561-228567: Automatic Attribute annotations - title block values
How do you set the material to automatically update in the title block if you change the material using Tools->Assign Material?
Answer: Input the following string <WRef1*0@Material> into the cell where you would like the material to display.
Is it really this straightforward? I am relatively new to NX (used only 8.0 and 9.0 so far) and so I assume there is some risk or flaw I have not experienced yet.
I hope this helps whoever is looking for a simple solution.
RE: NX TITLE BLOCK - MATERIAL
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
