standards for butterfly valve
Which standards has to refer while designing a double offset butterfly valve?
Pl. Mention design and testing standards.
Also for calculating valve torque for a double offset butterfly valve, what factors has to be consider like bearing torque, seating and unseating torque, packing torque, is there any standard for these calculations?
RE: standards for butterfly valve
MSS SP-68, and API 609 are the two main design standards
Thank you sir ...
