Parasolid export
Parasolid export
Hey guys..
Short question about exporting and importing of parasolids.
When I export a Parasolid from NX8.5.3., after that I import it again in NX (same version) I get the below result in part navigator.
Now when I double click (edit) the feature I get below message.
Which implies that somehow there is feature information to be retrieved and capable of editing...how can I accomplish this?
Ronald van den Broek
Application Specialist
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
RE: Parasolid export
www.nxjournaling.com
NX8.5.3 / TC9.1.2
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
And please do NOT read too much into the wording of the message as I've already stated that it's poorly worded and does mean what you might think it does.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
The problem is actually that we are moving to NX9 pretty soon from now. However some of our Licensees are staying on NX8.5 (or switching from 7.5 to 8.5) and we need to come up with a solid way (pun intended) to exchange our NX9 data with their earlier versions..
So probably Step would be our best bet, just need to come up with a solution for the drawings...
NX8.5.3 / TC9.1.2
File -> Import -> Parasolid...
...workflow rather then opening the Parasolid files directly using File -> Open...
Granted, we support both approaches, but in your case, perhaps the way I've proposed above would serve you better in the long run. And before you ask, nothing has changed in NX 9.0 or NX 10.0 with respect to these two alternative methods for moving Parsolid data from newer versions of NX to an older version.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Say that you design your parts in SE and use NX for Simulation, CAM etc, then you can "replace" the SE body and keep the work done in NX.
( Browse the Solid edge threads for a sample model to test...
Tomas
