API 653 Code issue
API 653 Code issue
API 653
12.3.2.5.1 a
A portion of the weld (of any length) may be removed and replaced as long as the replaced weld meets the size
requirements of API 650, Section 5.1.5.7, and the portion replaced does not represent more than 50 % of the
required weld cross-sectional area.
what is meant by portion in red. i am unable to understand "weld cross sectional area" how it will be calculated?
12.3.2.5.1 a
RE: API 653 Code issue
