FLOTHERM error. Can U make anything of it?
I installed my Flotherm CFD software (V2.1) and am getting an error message on startup.  Can you make anything of it?  Should it be cause for alarm?
"ERROR E/01025-Unable to access Solution Data <possible file permission problem or file-system is full?>"
Why would the code look for “Solution Data” when I hadn’t even specified a project (or built a project for that matter)?  This error message came up immediately when I started my first session.  It comes up whenever I open the software.
Thanks for your help!
Tunalover
