Grout under base plates in small quantity
I am looking for a grout available in small quantities to reduce waste because we often need less than 1kg or 1 litre at a time.
Suitable for horizontal or vertical surfaces.
Strength up to 60 MPa
Most structural grouts seem to come in 20kg bags or similar.
RE: Grout under base plates in small quantity
Two x 50lb bags were less than $50 total.
Most manufacturers make pre-bagged products in the 40 to 80 lb bag range.
I guess you could find some manufacturer who bags in small quantities but 1kg is very small. The price per kg would not make it very economical.
Any unused unmixed grout can be stored for a good amount of time. Place the bag in a 5-gal pail with a pail lid and it will keep it 'fresh' for a longer time.
Similarly with epoxy grouts.
Manufacturer's want you to use more of their product.
I always mix small volumes of grouts (and epoxies) via graduated containers in proportions stated in the product data sheets.
