structural modelling on sap 2000
Hi all,
I want to know how to connect slab to retaining wall at each floor levels in under ground structure.Do i have to draw a beam at each floor level on retaining wall and slab junction to transfer loads.
RE: structural modelling on sap 2000
You devide the wall to meet slab gap. No need to draw boundary beams.
If the nodes do not coincide, I think you should you the Edit Points > connect method.
