O-ring Expansion
O-ring Expansion
O-ring Expansion
Good Day,
i have a problem regarding the O - ring of our Transfer Pump of Spent Caustic unit. the O - ring expanded that caused to break the Mechanical Seal of the said Pump. the o - ring material was EP( Ethylene Propylene) and i checked that the chemical components of the spent caustic is compatible to the said material of the O - Ring. any other factor that may be the caused of o - ring expansion.
thank you and have a nice day.
RE: O-ring Expansion
What was the fluid being pumped?
How long was it in service?
What pressure service?
What temperature service?
What flow rate/pump rpm?
What did the pump seal manufacturer require in HIS bill of material for HIS pump seal?
1. Spent Caustic that contains
SPENT CAUSTIC Design Normal
Quantity :1800kg/hr (1.8m3/hr)
Components
NaOH: 3.1 wt%
Na2CO3: 0.3wt%
Na2S: 1.43wt%
H2O: 95.08wt%
Mercaptide: 73.48 wt.ppm S
Biological Oxygen Demand (BOD): 402 mg/L
Chemical Oxygen Demand (COD): 36261 mg/L
Oil/Grease (Maximum): 15 mg/L
Phenol (Maximum): 190 mg/L
pH: 12.53
Pressure: 700 kPa(g)
Temperature: 39 C
Density: 1000 kg/m3 (Assumed)
Viscosity: Less than 30 mPas (30 cP) (Assumed)
Higher Heating Value:
Design: 215.2 kJ/kg (51.4 kcal/kg)
Normal: 213.2 kJ/kg (50.9 kcal/kg)
2. RPM of the pump is 3530 RPM (designed)
I don't know the recommended service life for that material under very high pH conditions - EP( Ethylene Propylene) from your original posting - but the pressure and temperature are at least moderate.
But a 12 pH even at only 40 deg C may mean you simply cannot rely on the O-ring for a long time.
Ok sir, Thank You. For now we are looking for the possibility of the error in the temperature either in the product side or barrier side, since all of the O-rings of the pump expanded. Thank You for your information.
Can this amount of Phenol in the fluid may affect the EP O - ring? I read in the internet that Phenol is not compatible with the EP (Ethylene Propylene).
We can't answer the phenol compatibility question; you can.
Go to your local o-ring seller, and buy a few examples of your current material, and of every possible alternative you can speculate, given your newfound knowledge. Size doesn't matter much.
Put a sample of each material in a separate clean beaker.
Fill all the beakers with your spent caustic soup, and wait for something to happen. Given the strong expansion you report, there should be obvious results overnight or sooner.
Proceed accordingly.
In future, please refrain from duplicate posting.
In current time, please Red Flag your duplicate posts.
In the resulting dialog box, ask that the discussion be deleted.
Mike Halloran
Pembroke Pines, FL, USA
The first step would be to verify that the o-ring material is actually what it is advertised to be. Mistakes happen.
And use the term "swelling" instead of expansion, you will find more information.
Ok Sir, Thank You for your input and advise.
Have a Nice Day.
