set attributes in journal vice versa
Hi All,
I am trying to modify journal for change of cut direction and to get this I need to change my attribute called "VM_cutDirection" in my cam object. In my journal I can able to change through set attributes but I would like to automate little for this.
If my attribute is 0 then needs to set as 1 or vice versa. I am unable make if statement for that Can anyone help me in this here is my code.
CODE --> Attributes
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.CAM
Imports NXOpen.UF
Imports NXOpen.Utilities
Module ChangeCutDirection
    Dim theSession As Session
    Dim theUfSession As UFSession
    Sub Main()
        theSession = Session.GetSession()
        theUfSession = UFSession.GetUFSession()
        Dim WorkPart As Part = TheSession.Parts.Work
        Dim setupTag As Tag
        Dim camObjectTag As Tag
        Dim selectedTags() As NXOpen.Tag
        Dim selectedCount As Integer
        theUfSession.Cam.InitSession()
        theUfSession.Setup.AskSetup(setupTag)
        ' If there is a setup only then we go further
        If setupTag <> 0 Then
            ' Get the selected nodes from the Operation Navigator
            theUfSession.UiOnt.AskSelectedNodes(selectedCount, selectedTags)
            Dim ptr As IntPtr = New System.IntPtr
            Dim cycle_cb_fn As UFNcgroup.CycleCbFT = New UFNcgroup.CycleCbFT(AddressOf cycle_cb)
            Dim i As Integer
            'Loop over the selected nodes to take action
            For i = 0 To selectedCount - 1
                ' The selected item needs to be checked to take action
                action(selectedTags(i))
                ' Now if the selected item is a Group object then we need to cycle objects inside it
                theUfSession.Ncgroup.CycleMembers(selectedTags(i), cycle_cb_fn, ptr)
            Next i
        End If
    End Sub
    Function cycle_cb(ByVal camObjectTag As Tag, ByVal ptr As IntPtr) As Boolean
        Dim answer As Boolean
        ' Every item needs to be checked to take action
        answer = action(camObjectTag)
        Return answer
    End Function
    Function action(ByVal camObjectTag As Tag) As Boolean
        Dim camObject As NXObject = NXObjectManager.Get(camObjectTag)
        'Check if the object is an Operation
        If TypeOf camObject Is CAM.Operation Then
            Dim operationType As Integer
            Dim operationSubtype As Integer
            'Get the type and subtype of the operation
            theUFSession.Obj.AskTypeAndSubtype(camObjectTag, operationType, operationSubtype)
				theSession.ListingWindow.Open()
				theSession.ListingWindow.WriteLine("operationSubtype = " & operationSubtype)
		End If
			Dim oOpers(0) As Cam.Operation
			oOpers(0) = camObject
			WorkPart.CAMSetup.GenerateToolPath(oOpers)
	        	   ' Set cut direction
				'camObject.SetAttribute("VM_cutDirection", "0")  ' THIS SETS VOLMILL TO CLIMB
				camObject.SetAttribute("VM_cutDirection", "1")  ' THIS SETS VOLMILL TO CONVENTIONAL
			     ' Comment the following two lines to suppress the listing window
				theSession.ListingWindow.WriteLine("Parameters set in: " & camObject.Name() )
			Dim oOpers1(0) As Cam.Operation
			oOpers1(0) = camObject
			WorkPart.CAMSetup.GenerateToolPath(oOpers1)
End Function
End Module
