How to repair a damaged RAR file?
Hi guys!
I've download a big file more than 4 Gb and finally after several weeks i got a message during extracting from WinRAR, that my rar file is damaged.
Can someone help me with such complicated situation?
RE: How to repair a damaged RAR file?
Even better, retrieve it from a different archive, using a different transfer protocol.
In general, all compression schemes, like RAR, remove all redundancy from a file, so a single bit glitch makes it nonrecoverable.
Mike Halloran
Pembroke Pines, FL, USA
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
<Open the file in WinRAR (download from internet if you don't have one).
<Press your right mouse-button.
<Click on "Repair archive", or press Alt+R.
<Click on Browse button and select a folder where you want to keep the repaired archive.
<There will be two options ("Treat the corrupt archive as RAR" and "Treat the corrupt archive as ZIP").
<Select any one of your choice (or see which one will work) and click on OK button.
<Go to the folder where you have kept the repaired archive and open it (Repaired archive will be named as rebuilt.*.rar or rebuilt.*.zip, where * is the name of original archive).
If the guide above isn't effective for your damaged .rar file, then...
http://tonyshorten.hubpages.com/question/233108/ho... - thread where is discussed the same issue with .rar file
http://www.filerepairforum.com/forum/archives/arch... - open community for any experienced users
http://www.rar.repairtoolbox.com/ RAR Repair Toolbox - gives you the guarantee of fast and quality restoration, but of course it costs money
