NX - Edge Blends / Fillets seem to bog / slow model down - Suggestions?
First time poster, long time reader here.
I absolutely love NX, but I have one thing that keeps creeping up.
On several different part models I have worked on, each around 1,000 features/part navigator/tree items, it seems that when I get to the end and start adding Edge Blends (fillets) that the model just gets slower and slower. After several fillets (most are variable radius as part changes size/shape) it may take several minutes (maybe as long as 5 to 15 sometimes) to go back in edit these fillets or add new ones (Mainly seems to be on editing existing ones though). Taking preview off does help speed this up but then if you click ok to save changes then your wait begins. Gets frustrating after awhile. You see the end in sight with the last few touches but it may take you all day or more to finish.
I haven't seen anyone else talk about this so just wondering if just a setting change somewhere possibly or my computer hardware / software compatibility? When NX is churning away thinking, Windows task manager says I'm not even using 25% of my ram and barely any CPU.
NX works great otherwise.
Any thoughts/suggestions/links to other post appreciated.
NX 7.5 and 9 (better performance in 9)
PC:
Dell Precision T5500
Intel Xeon CPU - E5645, 2.40 Ghz , 2.39 Ghz (2 processors)
12gb RAM
64-bit
Windows 7
PC:
12gb RAM
64-bit
Windows 7
RE: NX - Edge Blends / Fillets seem to bog / slow model down - Suggestions?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Angle: 0.5
I have 3 or 4 times set feature to 0.0001 to get a feature to Sew together before (if that makes a difference).
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Typically part file is maybe around 40mb before drafts/fillets are added...around 100mb after.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Pretty small, but a lot of features placed on it. this part may be around one foot tall, Less then three inches thick.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
Initially we start off by creating a solid body by trimming reference boundaries(surfaces) and then sew that into a solid body. That lets us then do the 'easier' stuff (trims/cuts, slots, holes, etc.) through the built in feature and sketch tools as applicable. We also though have areas of the part where its created one area at a time, as it involves different final needed shapes in different areas (maybe creating a curving tube that keeps changing shape as it winds through the part here or there, etc). These sections, if you will, of the part are created using reference surfaces/bodies from WAVE geometry, ref planes, or other geometry to set up some of the known boundaries, then sketches/extrudes and/or surfaces (offset surfaces, surfaces created with curve geometry, through curves, sweep, etc) make up the rest of the feature generally (usually find a lot of Trim and Extend, Trimmed Surface, N-Sided Surface commands), followed by sewing that feature area together, then Unite it with the rest of the part. After uniting the final parts of the model together we apply drafts followed by the edge blends and we're done.
Hope I answered your questions there.
Since you mentioned it, I'll take a look at NX 10 to see what's new. Always curious on what new toys have been added.
Anyway, if you do give this a test, please let us know what you learn.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
