Asphalt Grade Breaks at Handicap Spaces
What are your thoughts on grade breaks in asphalt paving? Where I work some people are saying performing a grade break immediately outside a handicap space going from 1.5% (in hc space) to 3% (outside hc space) results in the 3% grade getting feathered back into the space thus being ADA incomliant. Right now we are working with a client who wants a handicap space in front of their building with a 5% cross slope on the non-handicap parking space beside it. I am not convinced it can't be done. After all, the asphalt grade is determined by the ABC beneath it. It would seem to me that if you get the ABC where it needs to be grade-wise (<2% in HC space and 5% in adjacent space) the asphalt would follow right along. I understand there may be slight roll on the asphalt surface between the breaks but nothing horribly noticeable. I am only asking because I have been practicing for a while and never heard of this being an issue. I suspect select contractors have made a stand it cannot be done in an effort to get out of tearing up and relaying handicap spots that were not graded correctly. I am interested also because this client builds all over the US and it is likely this has been done before. I am cautious to say it cannot be done when they have done it multiple times before in other parts of the country. Thank you in advance.
RE: Asphalt Grade Breaks at Handicap Spaces
Richard A. Cornelius, P.E.
WWW.amlinereast.com
