PH 2.5 -3 Election of appropiate stainless steel
Hi everybody,
which kind of stainless family you would use for an environment between PH 2,5 and PH 3. I am interested to knnow which family is the most appropiate only in term of corrosion resistant.
thanks in advance
thanks in advance
RE: PH 2.5 -3 Election of appropiate stainless steel
The most critical will be the temperature and chloride content.
The pH alone is not relevant information.
there is some material with HCl at 1%.
thanks.
http://tools.outokumpu.com/spt/corrosion/view_deta...
Any of the 6%Mo superaustenitic grades will work for 1% HCl at less than 40C.
