Standards help
Standards help
I remember, waaay back in the day when I was first learning how to draw, my instructor defined how borders needed to be drawn - specifically how far from the edge of the sheet (something like 8mm if I recall correctly). I also seem to recall that inside the border, views, dimensions, annotations, etc. should also be no less than a set distance from the border, for clarity - but for the life of me, I can't find in any standard where this value is called out (nor can I remember what the value he told us was - I generally just err on the side of caution and try to be as generous as possible). Certainly I can find the dimensions between border and sheet edge in relevant standards, but nothing inside the borders - anyone know where I might be able to find this info? Logically one might assume that if dim lines are to be ideally 10mm from an edge or surface in a drawing view (per asme y14.5-2009 1.7.1.2, with dims ideally being 6mm from eachother, then 10mm spacing from a border or title block edge, for example, would also be appropriate - I'm just looking for something more definitive. We have designers who are challenging our checkers when being marked up for having dims/section lines or other annotations too close to the borders, and we'd like to put a nail in this coffin either way.
RE: Standards help
If it's desired to control it you'll need to get company standards and HR involved.
This sounds more like a money wasting fight for control than a drafting issue.
RE: Standards help
Former boss with background in defense/automotive once pointed this out on a drawing of mine - but I don't have a reference.
I just try to keep far enough in from the borders so it doesn't look messy, no specific #.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Standards help
Bottom line is making the drawing easily interpreted.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
