Abaqus _Install_Linux
Hi,http://www.eng-tips.com/threadminder.cfm?pid=727
I am trying to install abaqus 6.14 on ubuntu 14 by using a mounted iso folder via the ./setup command but the compilation was aborted and I get the following error message :
"The installation should not be executed from the directory that contains the setup files.
Please change your current working directory and rerun the installation."
How I can fix this pb ?
Many thanks in advance.
RE: Abaqus _Install_Linux
sudo apt-get install libstdc++5
I progress step by step on abaqus, when I run abaqus cae the diplaying of the interface is very poor I can not see the menu only the workspace, below some error messages that I get :
-------------------------error messages----------
X Error: code 2 major 155 minor 3: BadValue (integer parameter out of range for operation).
X Error: code 169 major 155 minor 5: GLXBadContext.
X Error: code 0 major 155 minor 26: 0.
X Error: code 169 major 155 minor 4: GLXBadContext.
Warning: Your system need to be reconfigured to allow OpenGL
rendering to a pixmap or you will only be able to print to
raster formats.
----------------------------end message--------------
Thanks in advance for your help,
Harfbuzz
