Calcium Hypochlorite
Dears
I have to choose between two products of calcium hypochlorite ( HTH Easiflo Granules and HTH Shockfrom) from Accepta company to Sterilization permeate water from reverse osmosis which use for Dairy Processing. please for your recommendation and advice
Thank you
Thank you
RE: Calcium Hypochlorite
With the Shock which is a finer grade material, you probably need a day tank with mixer. If the material sits around for a long time, it will go stale.
HTH has a feeder for the Easiflow briquettes so there is probably less waste and simpler to use.
please what do you mean by feed system?
Thank you
The briquettes can be used with a solution feeder:
http://www.pollardwater.com/pages_product/CNOLF500...
While the fine material would have to be used with a day tank and pump.
Thank you
and for economic option HTH Easiflo Granules cheaper than Shock type for Kg
http://resources.pihomebuild.com/sites/851/docs/co...
http://www.google.com/url?sa=t&rct=j&q=&am......
Thank you
http://www.foodonline.com/doc/dry-tec-fg-calcium-h...
http://ncfreshproducesafety.ces.ncsu.edu/wp-conten...
Thank you
