Coiled Tube HS-90
Coiled Tube HS-90
Hello all,
What does the prefix HS stand for in the Coiled Tube HS-90 manufactured by Tenaris Coiled Tubes?
Could anyone provide the magnetization curve (B-H curve) of the Coiled Tube HS-90, which is made of the steel alloy A-606 type 4 molly?
Thank you.
RE: Coiled Tube HS-90
This alloy is normally desgined for magnetic applications, plus, B-H curves depend heavily on status of alloy. One might be hard to find a BH curve is readily available.
you may find a hysteresis loop from a low alloy carbon steel as a reference.
