It is not possible to make groups
Dear all
i've made a conical shell in sap2000 and i can't make groups for each level, i select any point or element at each level or both but when i make a group with these it is not useful and i can't use them for section group because there would be no output in these sections?
what should i do?
RE: It is not possible to make groups
Did you select the group uses in the dialog box?
