Interruption on Dimension Line
Hello guys,
I am facing a little problem.
How to create interruptions on the dimension line, not on the extension. The clipping is not method i am looking for.
Please find attached file and let me know.
Warm regards,
Akhtar Aziz
RE: Interruption on Dimension Line
Check under the dimension's Propoerties>Extension Line tab.
Depending on what you are dimensioning, you can slant the dimensions as Weavedreamer said and/or position the dimensions below the geometry.
Warm regards,
Akhtar Aziz
