Problem with explicit dynamics in ansys workbench
I'm new to working with asys.
the problem is that I need the simulation late 0011 s, implying that the processing time is 330 hours is too long.
I tried to change several option in ansys workbench but the program continues to create partitions 1e-9 which are too small to generate the simulation too late.
as I can do to make simucion done in time you desire without taking so long.
I am very grateful to the person who can assist me with this situation.
RE: Problem with explicit dynamics in ansys workbench
You are using explicit analysis - this solver is meant to be used for applications that involve very short duration not for long duration (in the order of miliseconds).
However - if you want to use it for long duration there are some "workarounds".
Please take a look at the two links below.
Link
Link
