when are process calculations
In the creation of a chemical process plant, are process calculations done and then chemical data sheets are made. So in short, the sequence will be simulation>heat and mass balance>process flow diagram>equipment list>process calculation>process data sheet>
RE: when are process calculations
Also, a lot of times there is recycle. Your process calculations may convince you to change the H%MB or PFD. Or, if there is no commercially available equipment that meets the datasheet requirements, you may have to go back to step one.
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
