NX9 - Journal Code to Switch Color Palette to "System" Color Palette?
Our templates are set to use the system color palette. However, a lot of files seem to creep up using the wrong palette and this makes many of our components appear the wrong color.
Is there a journal code that will automatically switch the color palette to the system palette when it is ran?
Also, if we set up the Customer Defaults to force everyone to use the system palette, will that change old files to the system color palette when they open them? I dont think so, but I figured I would ask anyway.
RE: NX9 - Journal Code to Switch Color Palette to "System" Color Palette?
I used this in the past:
Public Sub load_color_palette()
Dim rootDir As String = _
Environment.GetEnvironmentVariable("UGII_ROOT_DIR")
Dim colorPalette As String = rootDir & "\ugcolor.cdf"
Dim colorName As String = ""
Dim red As String = ""
Dim green As String = ""
Dim blue As String = ""
Dim rgbColor(2) As Double
Dim thisColor As Integer = 0
Dim textLine As String = ""
Dim lineCounter As Integer = 0
Dim myStream As Stream = Nothing
Try
FileOpen(1, colorPalette, OpenMode.Input)
Do Until EOF(1)
textLine = LineInput(1)
If lineCounter > 3 Then
colorName = textLine.Substring(0, 30)
red = textLine.Substring(34, 8)
green = textLine.Substring(45, 8)
blue = textLine.Substring(56, 8)
rgbColor(0) = red
rgbColor(1) = green
rgbColor(2) = blue
thisColor = lineCounter - 4
ufs.Disp.SetColor(thisColor, _
UFConstants.UF_DISP_rgb_model, colorName, rgbColor)
End If
lineCounter += 1
Loop
FileClose(1)
ufs.Disp.LoadColorTable()
Catch Ex As NXException
s.ListingWindow.Open()
s.ListingWindow.WriteLine("Error in load_color_palette: ")
s.ListingWindow.WriteLine(Ex.GetBaseException.ToString())
End Try
End Sub
daluigi can u help-me adpating that journal ?
what i want? : i want to when click on a but it loads the costumer default palette, or is there a way, like thru the ugii_env, to when i start the NX it automaticly loads the costumer default palette or one that i choose from a dir?
NX8.5 User
Quote (Kenja824)
The color table is saved with the part. What you specify in the customer defaults will only apply to a newly created (blank) file. Old parts will still use the colors they were saved with.
www.nxjournaling.com
Define whatever path you need to the your color palette file (the variable named here "colorPalette") and the above code will do exactly when you need...
but this:
CODE -->
rgbColor(0) = red
rgbColor(1) = green
rgbColor(2) = blue
will not return me error if my pallet colors difers from the system default ? i just need to do this? :
CODE -->
Dim colorPalette As String = rootDir & "c:\xpto\Mycolors.cdf"
Try
Do Until EOF(1)
rgbColor(0) = red
rgbColor(1) = green
rgbColor(2) = blue
End If
lineCounter += 1
Loop
FileClose(1)
End Try
End Sub
NX8.5 User
