When failed features won't regenerate
So,
I have a feature tree filled with red-lettered features. All that is required to restore the feature is to edit the definition and immediately accept. The feature will be repaired without any changes made. So my question: is there anything that will save me from repeating this arduous procedure for my entire tree? The control+G command does nothing.
Possibly related: The regeneration manager lists features as failed that look completely fine otherwise.
Thanks all. I have faith that you are smarter than I!
RE: When failed features won't regenerate
Sounds like you have some common reference that Pro/E is automatically updating when you do the redefine.
