NX 6 Technical Help: Got a new job that uses NX 6
I've been using CAD for a while and used NX in school but I want to improve my knowledge before I start working with it. So to all you pro people out there I want to know some technical things:
1. Hotkeys: how do I make new hotkeys/ macros, do you have any personalized ones that you like. I've found lists of standard ones online and they help but the last CAD program I had used at least half the keyboard so I wouldn't mind adding to that list. I know there's some way in SolidWorks to do macros called API so is there anything like that in NX.
2. Once I make these will they transfer over with my new personalized user setting. I'm not sure that's what it's called but you know you can change how many buttons you see by going from standard user to advanced user.
3. Are there any tutorials, or videos that you think are very good at teaching sheet metal. I know I can look this up online but if you know of any pass that along.
RE: NX 6 Technical Help: Got a new job that uses NX 6
After any sort of change to the user interface, including the editing and assignment of 'hotkeys', you should create and save your own Role, which can then take with you if you move to work on another system.
That should get you started.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Add existing curve still exist also in NX10.
You can only select unparametrized curves
We use it when you import curve from another CAD Software with DXF for example, then you can add it into a sketch.
Didier Psaltopoulos
http://www.psi-cad.com
