Is it possible to add more scale ratios to the base view dialog?
Is it possible to add more scale ratios to the base view dialog? I use a lot ratios that fall between the standard ratios and it would be nice to have them defined in the ratio pulldown in the base view dialog.
NX9
Waiting for 10.2
RE: Is it possible to add more scale ratios to the base view dialog?
If you are looking for more scales in the pull-down ~ I doubt if you can do that without extra programming
NX9
Waiting for 10.2
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Is there a way to set the template view scale and enforce it? I've been working with a drawing template recently; I added a dummy component slightly larger than the parts I plan to detail and set the view scale to 1:1. When I use the template on my actual part, the views get changed to 1:2 scale. I created an expression in the drawing template and tied the scale of the views to the expression value just so the drawings would stay at 1:1 scale.
Creating templates with predefined views sounds like a good idea, but in my experience they don't work. What did I do wrong? Nevermind, don't answer here; I don't want to hijack this thread. I'll start a new thread on the topic.
www.nxjournaling.com
NX9
Waiting for 10.2
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
